Monitor Connection Question
Shadeslayer110
490
Hi,
I have a question about connecting my monitor to my case. My monitor is the ASUS MX239H, and it comes with many wires, and the manual says that connect the ones you need, Which wires do I need to connect? The wires are:
VGA cable
Audio cable
Power cord
Power adapter
Quick start guide
HDMI-to-DVI cable
PC:
Processor: Intel i5 4670k
RAM: Corsair Vengeance Low Profile 8 GB 2x4
Motherboard: ASUS Z97 A
GPU: EVGA GeForce GTX 760 Superclocked
Hard Drive: WD Caviar Blue 1 TB Samsung 840 EVO 120 GB SSD
Optical Drive: Asus 24x DVD-RW Serial-ATA Internal
Power Supply Unit: EVGA 500B 500W 80PLUS Bronze Certified
Heatsink Fan: Cooler Master Hyper 212 EVO
OS: Windows 7 Home Premium 64-Bit
Case: NZXT Phantom 410
Monitor:Asus MX239H, 23-Inch Full HD AH-IPS LED-backlit and Frameless Monitor
Mouse: Steelseries Sensei Frost Blue Keyboard: Logitech K360 Wireless Keyboard
Wireless Internet Card: TP Link N900 Express Adapter
Steelseries QCK Black Mouse Pad
Total: $1549
Connect the power cord to the wall and to the power adapter.
Connect the power adapter to the monitor.
Connect the DVi/HDMI cable to a DVI port on your GPU (or if you do not have a GPU, the I/O ports) and the HDMI side to your monitor.
If you want the crappy sound from the speakers in the monitor, connect the audio cord from the Stereo Out on your PC's rear I/O ports to the audio connection on the monitor.
Ignore the VGA able.
Oh and the Quick Start Guide is NOT a cable.
I'm sorry, I just copied the wires on the website and I missed that. Thank you!
