Monitor edges look fuzzy?! HELP!
newpcgaming
107
So today's my birthday and I received a 28 inch Asus VN289H monitor. I hooked it up and turned it on and immediately noticed that the edges of test and images looks blurry. It bothers me immensely to the point were i want to request it be sent back, but i don't want to be a pain for my parents. please help, only around 2 out of 100 reviews on newegg mentioned my problem, so i have hopes it can be fixed. HELP PLEASE!
getting somewhere mate,
make sure the settings are above - with hdmi only etc & all the settings are as my previous posting
click windows start bar
open control panel
in search box type cleartune
open the adjust cleartype app
make sure enable cleartype is ticked ,click the next box & follow the prompts
it should say your monitor is set to its default resolution ,if not change it
follow the prompts
if still not acceptable mate
then it maybe the dpi settings
right click on desktop
select personalize
bottom left of tab select display
ensure smaller - 100% box is ticked
apply
short of that mate its all you can do ,everything else will eb down to the monitor
on a hdmi capable monitor & gpu always use the hdmi cable only though mate
its...
I dont know how to check sRGB, the windows is taking up the fullscreen with no boarders, windows 8.1 os, and a GTX 770 4Gb oc2 (about to upgrade to a GTX 970).
I switched from a 21.5 inch Samsung that frankly just had better image
Right click on your desktop
Select screen resolution
Select 1920 x 1080
Set the hertz box to 60
Click apply & accept the resolution change.
Right click on desktop again
Open nvidia control panel
Open adjust desktop size & position
Set scaling option to 'no scaling'
So you now have
1. Connection by hdmi only
2.resolution set to 1920 x 1080 60 htz
3.Nvidia option set to no scaling
Correct??
Do you have a full screen image with all the desktop showing now ??
And just the fonts & icons are fuzzy??
If so boot a game up (any game)
Does this show clear & sharp??
We'all try again now I'm in front of my pc
With just HDMI connected
In nvidia control panel
Adjust desktop size & position
Make sure no scaling is ticked
Perform scaling on display is selected
Resolution is 1920 x 1080
Refresh rate is 60 htz
Click apply
Accept changes
Still fuzzy??
Latest posts
