UltimateRob97 Reputable Feb 4, 2015 120 0 4,690 Oct 11, 2015 #1 Hello, I have plugged my xbox one in to my monitor, it has speakers but no volume control so I don't know what I can do to change the volume, can someone help, thanks
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Oct 11, 2015 #2 There have to be buttons on it. Check your manual. Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Oct 11, 2015 #3 The volume controls are most likely buried in the monitor's settings. As noted, read your manual. Upvote 0 Downvote
C Cons29 Splendid Feb 10, 2010 5,455 4 26,960 Oct 11, 2015 #4 look closer, check your manual (it may be capacitive buttons not physical buttons) Upvote 0 Downvote
S Suzuki@1473780084@1473780163 Dignified Mar 8, 2015 5,280 1 15,960 Oct 11, 2015 #5 Sure it's not just a 3.5 mm HDMI or DVI -> HDMI pass through? Why did you not include monitor make and model? Upvote 0 Downvote
