C cheryl.mcmillan Feb 3, 2019 3 0 10 Feb 3, 2019 #1 My monitor is connected by via cable to pc but message still displays no signal, vga recommended
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Feb 3, 2019 #2 Is your monitor set to use the input that you've connected the PC to? Not all monitors automatically switch inputs to the active one. Upvote 0 Downvote
C cheryl.mcmillan Feb 3, 2019 3 0 10 Feb 4, 2019 #3 popatim : Is your monitor set to use the input that you've connected the PC to? Not all monitors automatically switch inputs to the active one. Upvote 0 Downvote
C cheryl.mcmillan Feb 3, 2019 3 0 10 Feb 4, 2019 #4 Hi, I have no idea. It's got blue ended vga cable connecting monitor to pc but message still displays no signal vga recommended. I think it's possibly the pc, Upvote 0 Downvote
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Feb 4, 2019 #5 Which monitor do you have? Where is it connected to on the PC? What are your PC's specs (Make&model#'s of the parts)? Upvote 0 Downvote
