monitor help !!!
momo eric
389
hello ,
i wanted to know about dell S2240L 21.5" ips monitor ..i have no knowledge about monitor ...
Is this monitor good for gaming or will i get a better 1 at this price range ?
i m open to any suggestion.
thank u
i play mainly witcher 3 and bf4 ..
my current rig-:
i5 4690k , r9 280x , 2x 4gb veng 1866mhz , seasonic s12 620w , intel 530 240gb ssd and 1tb hdd .....need to buy a new mobo deciding on msi gaming 3 or 5 ..
it would be nice to know if u could help me out in choosing .... i m siding towards gaming 5 because getting info about the mobo will be easy about ocing ... if i buy gaming 3 my budget for monitor will increase to 12500rs ...
You need a faster monitor for BF4. If you play with that monitor you'll think it is good, but once you get a TN panel monitor with 2ms response time you'll know why you need a TN panel monitor. I suggest looking for this criteria in a monitor: 2ms and TN panel. It makes a huge difference for BF4, which is the game I play the most.
so ips panel suckz ? i was using acer S200HL monitor 20 inch ... but it doesnt have hdmi output wanted a little better monitor 22 inch and with hdmi output ... does the image clarity differs when u use hdmi and with dvi... hdmi gives better image ? or are they practically same
I'd get the BenQ instead. The Acer is a IPS and I'm guessing it is slow. Often monitor makers lie about response time to make them look better than they are. I'd suggest sticking to TN for BF4.
