monitor help
insadraon
unsure where to put this exactly doesn't seem to be a right hardware forum for it, i got an emachines runing XP, we just moved it from house to house and i hadn't had a chance to check it before it was moved, i plugged it in and i can't get a signal to my monitor, i tried a second monitor, i tried switching video cards no luck, the comp has power, any ideas/suggestions?
i've alrealy tried switching monitors they have thier own cables and i've tried an apg card a pci card and the onboard input with no vid cards installed no luck any other ideas? and thx for trying and for future help :)
No it shouldn't, but I have seen it.
Plus, the primary cause for no video, AND, not beeps, is either a loose ram chip, or CPU.
Most everything else will cause beeping.
The other options are less inviting.
If the CPU is dead (or the mobo), a scanner will show 00/FF, there ususaly will not be any beeps.
Well, it is an emachine. Could be anything, even voodoo. We had one of those once. Only machine I ever saw fry a PSU...three times. :x
Hmmm, maybe my pin cushion is working...
Naw. The black Emachines (owned by Gateway) are rather good. Computers frying PSU after PSU is not unheard of actually. The most common cause of that is a short on the motherboard or component that draws too much amps, or causes heavy fluctuation in power requirements. Either way, that is not an Emachine exclusive issue.
It is in my house. This was back when they were new. Celeron 333 it was... *enters Memory Ln*
It was likely the proprietary mobo. They did send us a brand new machine after the first blow out. We purchased a stronger PSU after the second. The last one blew in record time. 🙁
i got it figured out seems its something wrong with the harddrive, got another comp and hooked it up slave and comp did the same thing, so bought a new comp and sold the old one to a friend so he could fix it up to have a comp of his own, thx to everyone 4 their help :)
