HI,
I have a monitor with 1 HDMI port and 1 DVI-D port. I used to connect my monitor to the PC using a DVI to HDMI cable and my ps4 to the same monitor with a normal HDMI cable. But the solution suddenly stopped working, I don't know why.
Now the problem is while I am using that DVI to HDMI cable to connect my monitor to my PC, there is no signal. But If I connect the monitor to PC with a normal HDMI cable it works fine, and after my system booted to the window screen if I unplug HDMI and plug the same DVI to HDMI cable, the cable works. Cable is fine I checked with a new one, just in case. Can anyone help me solve the problem?
System config
Dell 24 inch led
AMD RYZEN 1700
8gb ddr4
Gigabyte g1 gtx 1050ti
asus Strix mobo
Thanks.
System config
Dell 24 inch led
AMD RYZEN 1700
8gb ddr4
asus Strix mobo
Thanks.
