[SOLVED] Monitor loses signal randomly
RedPanther
5
This might happen when I'm gaming or (more commonly) when I browse the internet (I haven't been gaming 9/10 of the times this has happened) or when the computer is not in use. It will just randomly go to "no signal" and the computer itself will lock up (I hit caps lock and the light doesn't light up) but the computer as a whole doesn't do anything differently. Lights are still on fans are still running at normal speed etc.")
Here is what I have tried so far:
  • Reinstall Graphic Card drivers
  • Reseat GPU
  • Install Gpu in a different PCIE slot
  • Use a different cable (HDMI)
  • Use a different monitor
  • Boot from a USB drive into a Kubuntu OS
  • Hitting windows+Shift+Ctrl+B doesn’t work
  • Reset windows (without losing files)
  • Checked temperatures and all are good
Specifications:
Operating System
Windows 10 Education 64-bit
CPU
AMD Ryzen 5 2600 Pinnacle Ridge 12nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1066MHz (15-15-15-36)
Motherboard
Micro-Star International Co. Ltd. X470 GAMING PLUS (MS-7B79) (AM4)
Graphics
GMX27F144Q (2560x1440@144Hz)
2047MB NVIDIA GeForce RTX 2060 (ZOTAC International)
Storage
223GB KINGSTON SA400S37240G (SATA-2 (SSD))
931GB Seagate ST1000DM010-2EP102 (SATA )
465GB Western Digital WDS500G3X0C-00SJG0 (Unknown (SSD))
Audio
NVIDIA High Definition Audio
Did you ever find out the cause for this? I'm experiencing this EXACT same problem you described after I recently upgraded from rx480 to gtx 3060. This issue has been plaguing my experience since.
