[SOLVED] Monitor makes noise when off
Jan 22, 2020
50
Its time To go sleep so I shut down my pc and i heard noises coming from my pc.. After pressing Off but ton To fully cancel pc getting power i still heard noises and then i realised it comes from my monitor.. Well, Then i unplug all cables from the monito but still makes noise without having any power.. Its Been 10min and still making.
Probably a capacitor in the power supply for the monitor. If you monitor has a LED light on the power button press the power button a couple times and see if you can get the LED light to basically discharge it.
buzzing is usually not harmful, and in cheaper electronics usually a sign of cheap components.
Latest posts
