Question Monitor mount?
Sep 1, 2024
5
I'm currently upgrading my build and am looking at three 34" curved monitors. I was hoping to find a mount that could accomodate all three monitors, but so far I have not had any luck finding anything. The closest I've found is triple 32" mount. Does anyone know of something out there that would work?
Make and model of the monitor's you're looking at? Curved monitors will need more space with regards to a mount/arm. The arm you're looking at would most likely be appropriate for flat panelled 32" monitors. I think you'd be best off going with three separate monitor arms, that clamp to you r desktop/table top.
The monitors I'm looking at are the MSI mag342cqpv. I am totally fine with a clamp style arm, i would prefer just using one mount over three. If that's what I gotta do I'll do it, just hoping someone knows of something I haven't found yet. Kinda hard to believe triple mounts for 34" monitors don't exist yet.
Looking around, I don't see any stand that would take 3x 34" in a single mount.
Looks like it will be 2+1, or 1+1+1.
Ya, it is looking that way. I find that quite surprising, triple 34's has been done so many times, crazy that a suitable mount doesn't exist for this.
Another try:
Desk mounts may damage your desk, and three may be a problem.
At Home depot or such, you can buy laminated countertops of all sizes.
Lay one on top of your desk and screw three mounts to it.
It is always nice to have larger desktop size.
