monitor not coming on
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Have an old computer that had a dual video card but it broke so I
installed another video card but not a dual one. Now I only get a
black screen when I turn on the computer. Anyone have any ideas of
what I can do?
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Hardware-monitor-coming-ftopict554797.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1762151
Do you have another video card to test the motherboard out with? It's quite
possible the computer's motherboard went bad. You're going to have to
troubleshoot each item one by one. You're going to have to remove any and
all devices that are connected to your motherboard. Just leave the memory,
processor and the video card in there. Check to see if you can get it to
boot that way. If not, you're going to have to try and replace each main
component out with another one to test and see which one is giving you the
problem.
Nocturnal
http://www.spywaretalk.org
"Kenny27" <UseLinkToEmail@WindowsForumz.com> wrote in message
news:3_1762151_97b1861a68c84f34472ac2034d70012d@windowsforumz.com...
> what I can do?
> request
> Topic URL:
> problem.
> Nocturnal
> > what I can do?
> > request
> > Topic URL:
HI!!!
>>I have one of those USB Sandisk Mini-Cruzers. If it is plugged in, my PC will boot but suddenly freeze and the monitor stays black. As soo as I pull that little thing from the USB port, the PC continues booting and the monitor lights up and all is well. Check around you to see what USB things you may have plugged in..Flash cards, floppy drives, etc.
