Monitor not displaying anything after logging in, startup errors
ok...we have to try another way then...
open cmd at elevated level...
type 'diskpart' to go to diskpart command...
then type 'list disks' to get a list of all the hdd/ssd...u have to identify the target disk from this list...
then 'select disk 0'(assuming 0 is ur disk assignment)...
then 'list volume' to list all the volumes in disk 0...
then 'select volume 1' (again assuming 1 is the target volume)...
then 'format fs=ntfs label=(name) quick' to format the drive...
refer to this for more details...or google diskpart...
http://www.jwgoerlich.us/blogengine/post/2009/11/05/Use-Diskpart-to-Create-and-Format-Partitions.aspx
u have to find a way to use disk management, partition wizard and diskpart in tandem...i cant remember the exact flowchart, but when i had similar issue around a year ago, it was resolved that way....so i m sure it can be done...
