I bought a new computer, but i didnt have a DVI-D adapter, so i connected him in the motherboard(VGA) and stay using the integrated graphics from the Ryzen. Then i bought the adapter but the monitor was showing "Check signal cable - DVI". I returned to the VGA and started searching in the internet. I changed my BIOS to use the PCIE as the primary video source and another setting i dont remember, and i changed something in the monitor settings. I disabled the integrated graphics (not uninstalled) and enabled the GPU drivers, then restart my computer.
I tried with the adapter but the "Check Signal Cable" message appears, then i returned to VGA, but i didnt get any signal, the screen shows the "Analog" in the left top, then the screen turn off and the button starts to blink.
My setup:
ASUS Prime A320M-K/BR
ASUS GTX 1050ti PH
1X8gb RAM 2133Mhz
Ryzen 5 2400G
Thermaltake 430W
Monitor: Samsung S19c301F (1x VGA, 1x DVI-D)
I have a VGA cable and an adapter VGA (F) DVI-D Dual link (M).
My setup:
ASUS GTX 1050ti PH
1X8gb RAM 2133Mhz
Ryzen 5 2400G
Thermaltake 430W
