[SOLVED] Monitor opinion / question.
reaume_23
Commendable
Sep 29, 2017
31
I currently own a Pixio px 276 2560x1140 144 hz monitor.
CPU is Ryzen 7 1800x
GPU is 1070ti
16gb ram oc to 3000
I’m looking at two monitors as potential upgrades. One is a TN panel the other an IPS. Price is similar. I’m been doing research and keep finding mixed opinions on IPS vs TN panels and most of the info is from very old posts. I have no experience with IPS as all mine have been TN.
which would be a better choice and would they be better than what I currently have? Will the IPS panel show a lot of improvement for color?
LG 27GL83A-B
Dell S2716DGR
Thanks for your time
Yeah the dell seemed like a good deal at first until I looked deeper into its ratings. I’ll definitely check out the model you sent as well. I appreciate the input
