Question [Monitor] PRISM M27EQ 165Hz 1ms 27 inch LED 2560 x 1440 QHD Gaming Monitor + Remote = $249.99
Apr 30, 2019
I found this on Reddit threads,
[PRISM M27EQ 165Hz 1ms 27 inch LED 2560 x 1440 QHD ] - i've never heard of this brand but as far as looking for the specs it's great for the prize.
will check upon it much detail after posting this thread.
Here are the specs for the monitor
  • 27 inch QHD Real 165Hz 1ms Response Time Gaming Monitor [DP 1.2 - 165Hz / HDMI 2.0 - 144Hz / HDMI 1.4 - 75Hz / DVI - 60Hz]
  • Panel Type: LED, TN Panel (Anti-Glare / Hard Coating 3H) 16:9 wide , VA / Resolution: 2560 x 1440 QHD
  • AMD Free Sync / LOS (Line of sight) mode / Over Drive / Flicker-Free, Low Blue Light / PIP & PBP / Ultra Vivid
  • 300 cd/m2 Brightness / 170(V) x 160(H) Viewing Angles / Built in Speaker: 3W + 3W Stereo / VESA Hole
  • Inputs & Out Port: DP 1.2 / HDMI 2.0 / HDMI 1.4 / EARPHONE OUT / AUDIO IN / DC
http://www.overclockmonitor.com/monitor-29.html
Looks like site is brand new, recently opened store. (Grand opening)
Any ways what do you guys think?
Let me know about this model
If you are a gamer. You care about refresh rate and resolution its perfect. However it has not so good color accuracy having a contrast of 1000:1 is pretty low. Its not ips making the colors already a bit lower quality. So if you care about image quality this is not the one for you. For fast paced gaming like csgo its a perfect option.
