monitor problems
Tom
1,720
Archived from groups: microsoft.public.windowsxp.basics (More info?)
My monitor is a bit old but a good Micron from 95. I just
installed Windows XP and the image starts out fine but
then gets so fuzzy I can't do anything.
Anyone have that happen before?
Help.I dont' want to buy a new monitor.
>-----Original Message-----
You might try going to the web site of your monitor mfg. &
see if there is an update for your monitor for XP.
Your monitor is 9 years old? You can buy a new, 19 inch CRT for about $250.
"tom" <birch444@hotmail.com> wrote in message
news:9c9b01c4866c$0818ced0$a601280a@phx.gbl...
Fuzzy is a monitor problem, nothing to do with software. You can go buy a
new CRT monitor pretty cheaply these days. Best Buy sells 19" for $150 or
17" for $100 at the moment.
Alternatively you can frequently go to Good Will or a similar thrift shop and
get a used one for $10.
Bill -- (Remove KILLSPAM from my address to use it)
