baconieatdat :
i dont know how to do it through catalyst control center, there doesnt seem the be an option, i have to use the buttons on my monitor to change display from 1:1 to full because it automatically changes to 1:1 when the game is launched
So youre saying that if you play games on the monitor the scaling is done gpu side, but when you play on the "hdtv" the scaling is done monitor-side?
To sort it do this:
1 In AMD control centre (right click desktop) click on the my digital flat panels menu and select properties (digital flat panel) and choose the display you want to configure
2 Check the enable gpu scaling box
3 Choose the GPU Scaling method desired and click on Apply. There are three different GPU scaling modes that can be selected...
