[SOLVED] Monitor settings partially disabled after reset on BenQ PD2700U ?
What exactly did you reset?
Solved. This happens when you are in HDR mode.
Much potential for confusion exists since there are at least 4 different ways to change monitor settings and they all interact with each other in different ways
1 - using NVidia control panel
2 - using BenQ’s DisplayPilot software
3 - using hardware monitor buttons
4 - Wndows Display Settings
Adding to the confusion there are two different HDR modes, normal and emulated.
Any documentation or tutorial only deals with one of these 3 options.
