[SOLVED] Monitor shows pixels and some strange symbols ?
Blackknight123
47
ok so my computer suddenly shut down and rebooted and then monitor shows pixels some strange symbols and so on.
My question is can i save this old garbage from its death ?
It worked partly when going to safe mode but then i tryed reinstalling Windows 10 where now pixels stayed but i cant get it to load anything ?
There's only so much you can explain with text where you actually need the aid of other media to help corroborate your scenario/story. Mind sharing pictures of what you're seeing? Also, to add, you forgot to mention the specs to your build. Please list them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS: version(not edition) of Windows 10
Monitor:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
Monitor:
View: https://imgur.com/a/i536gLG
GPU: ATI Radeon 4650.
CPU: AMD Althlon II x2 .
RAM: 2GB.
HDD: SATA 500gb.
OS: probably latest version since i did iy like yesterday.
Monitor: i rly dont know its brand is AOC.
Chassis🙁 If you mean case by it) is some Super ritemaster.
PSU: iam pretty sure 450w.
PS: i did it from my memory since some i dont know some i cant see. View: https://imgur.com/a/i536gLG
"You said you did spec from memory , download belarc advisor , its free it will tell you everything you need to know about your pc , too much to list here"
I can't download anything cos I can't use pc yes?
