Monitor Stand Help
Hoppin
137
I have the Acer K242HL and i see that on the back there are 4 screw holes for a stand. i am planning on getting another one but i cant find a stand for 2 monitors.
Thank You
I would guess that it will fit. Unfortunately Acer does not list any details more than it supports VESA brackets. Either check the manual or measure the holes (center to center, up and down) to be sure and compare them to the stand. Note there are two sets of holes on the stand.
what do you mean measure the holes?
Simply measure the distance between the monitor VESA mounting holes. You mentioned them in your post. Then compare them to the holes in the bracket on the stand. The stand that you linked has mounting holes at the dimensions below.
VESA Holes 75x75mm and 100x100mm
i think its 100mm. i measured 4 inches and i converted to 101mm
