Monitor stuck to DVI
May 22, 2018
5
My monitor is stuck on a DVI port, but i want to load up VGA I have a Hanns G HL231. Also the monitor isn't being detected the cabled are fully locked into place. please help.
I've tried that but the monitor just goes back to dvi-d but it's a vga going into a dvi both the cable and ye converter is brand new out of the packet
They are both plugged and locked so they are not loose connections I have one other display which is my tv which is connected but a hdmi
No I have two displays one connected to a vga and a tv with a hdmi connected which they are both connected to the graphics card the monitor is stuck on a dvi input which I need to change it to a vga, when I switch the analog to vga is automatically switches back to dvi after the pc is turned on
