[SOLVED] Monitor to 4K tv display
maldboy
BANNED
Aug 20, 2019
Hello,my pc supports only dvi and vga.
My montior supports vga and hdmi,i have conected the monitor to my pc with vga cable.
The monitor has hdmi also,i input hdmi cable to my monitor and to tv.It doesn't work.,no signal.
Is there any suggestion to make it work?
It's even possible to work in that way? HDMI to montior and to TV
I believed you are trying to connect PC to monitor using vga cable.
Next u are trying to connect PC dvi to the HDMI port of the TV. U just need a convertor.. dvi to HDMI....
You can't actually connect 2 output devices this way.
No mate no.
1-My pc have VGA port
2-My Samsung monitor has HDMI & VGA ports
I have connected my PC to MONITOR using VGA cable.
Now my monitor have 1 port free,HDMI.
Can i double screen the monitor with hdmi connected to samsung monitor and tv ?
Your monitor HDMI is a receiving input to display an image... Your Samsung TV is also a receiving input port... Between these 2 port, there is no source.... An output signal.... Got it?
