Thanks people for your responses. But, I do not see what I'm looking for in any of the offered possibilities.
1. The Resource Monitor only monitors drives.
I cannot monitor transfers between partitions especially on the same drive.
Plus it is very "ham-fisted".
Accurate transfer rate figures are not possible as far as I can see.
I did not see any way to log transfer data to compare and reference later.
2. Drives Meter does allow monitoring transfers between partitions.
But, it also is very "ham-fisted".
Accurate rates again are not possible, nor are logs.
No more than 4 partitions can be monitored at any one time.
3. As far as I can see CrystalMark can only benchmark from its own inputs,
not monitor what the drives are doing in the real world.
4. I have also tried HDTune Pro.
It does the type of job I'm looking for.
It turns out graphs, screen shots, logs, etc.
It comes very close to what I am looking for.
Except, that it does not monitor partitions, only drives.
I have 4 internal HDDs:
2x 1TB drives split into 2 drives -
1 RAID0 with 1 partition, and
1 RAID1 with 2 partitions
then,
2x 1 TB drives as RAID1 split into 3 partitions
Then, there is a docking station where several non RAID drives ranging from 160 GB to 1.5TB with 1 to 3 partitions on them are accessed.
The docking station is USB 3.0 capable. I am running it as USB 2.0 right now.
The USB 3.0 PCIe card arrived just before beginning this post.
I want to check the real world operation of all of these drives and their interactions internal and external USB 2.0 and 3.0.
Am I wrong in my assessment of the apps offered or are there other possibilities to be tried?
Thanks again for your inputs.
EDIT:
Yes I am Using Win7.
These are all SATA drives
I also have 2 IDE drives.
But, it is not my intention to use them.
