I was playing one day and my computer froze all of a sudden, so I turned it off and back on, when It turned back on it said "NO DVI SIGNAL" so I just unplugged and replugged the monitor cable and pc cable, it still said the same thing, I checked the cpu socket on my motheboard, none were bent, but when I checked the head of the monitor cable that connects to the gpu one of the pins were bent, can this be the problem for why my monitor isnt turning on? But then, I thought about it and if it were working before, why isnt it working now? Please help! Im only 16 and I dont got much money left if any pc components are broken, my specs are
GTX 1060 XLR8 PNY 3GB
I-7700k CPU
ASUS ROG STRIX B250H MOTHERBOARD
CORSEAIR RBG 2 8GB STICKS OF RAM
850W BRONZE POWERSUPPLY
Please comment if anyone knows how to fix this problem! Thanks!
And my monitor is an Asus 144hrtz 1ms response time 24inch monitor with nvidia 3D vision and you can use hdmi on it!
I-7700k CPU
