Hi everyone! From about 1 week i have this problem on my pc: sometimes the monitor turns off but the audio and the pc still working and i can hear pc' fans turn very fast. So I must press a button under power button on my case for a fast reboot. It doesnt matter what im doing with my pc: it happens randomly (one day it happens 2 times, another day 5 times...). It happens when i play videogames, when i watch YT video... also when im not doing anything. In the event viewer i have two errors: The Kernel-power 41 error and the evntLog 6008 error. A friend told me that it is a Mother board problem.
Another friend told me this:" or the RAM memory has some problems or some drivers are in conflict with each other. The fastest thing would be to try to update the chipset drivers and other main drivers (including bios update). If this does not work, you could try installing Windows from scratch. Last chance, change the ram banks ..." But Intel Driver support assistant says that i havent to update anything. Maybe i need to update the bios, but it is necessary? I had a similar problem moths ago, but it was a cpu cooler problem and i didnt need to update the bios, but in this case all all temperatures are ok. What i should do? Thanks for reding!
My pc:
CPU: i5 6600k 3.5 GHz OC to 4.4GHz
GPU: Asus Strix GTX 1060 6gb (3 GPU's fans)
MOBO: Asus z170-A
RAM: Viper Patriot 16GB (4x4) DDR4 3000 MHz
PSU: Corsair CX750M
CPU COOLER: MasterLiquid 120 Lite CoolerMaster
SSD: Samsung Evo 232GB
HARD-DISK: Seagate 1TB 7200 RPM
CASE: InWin 303 Nvidia Edition
FANS: x2 Corsair AF120 Quiet Edition (LED red) 120 mm
x1 Case's Fan (LED green)
x1 CPU COOLER's fan 120 mm
x3 GPU's Fans
Monitor: HP Pavillion 22xi (1920x1080) HP x20LED (1600x900)
OS: w10 pro
My pc:
MOBO: Asus z170-A
PSU: Corsair CX750M
x3 GPU's Fans
OS: w10 pro
