Monitor will not stay on
danny23
Commendable
Dec 31, 2016
8
Viewsonic 2255 monitor -- will come on for a bit and then turn off -- turning on and off brings it back on but then goes black after a bit -- will run longer if continued use and if resolution is reduced --blue on light stays on indicating signal and does not flicker -- had an on and off with another viewsonic and replacing power cap fixed -- I do not see an issue with caps on the board and indeed tried putting in a new board (cost was $40) -- but still does same thing. Stays on a bit longer with a vga cable than the dvi. Perhaps replacing some of the caps with a higher voltage rating?
Suggestions appreciated.
