Question Monitor with how much Hz should I get to get the best out of my specs?
Nov 11, 2023
4
My specs are:
Ryzen 5 5600
RX 6700 XT
32 GB Ram
With this PC I won't hit more than 90 fps in most newer games on ultra settings in 1080p. So should I go with 120/144/165 Hz monitor? Or maybe even less? I want to have the best picture quality and biggest smoothness. If anyone wants to recommend any specific monitor my budget is 240 USD.
Single monitor or multiple monitor setup?
And other criteria?
For other criteria, here's an example of my criteria, for good monitor to my build (1080p).
Size: 24", 27" or 32" (1080p does well on 24" and 27", 1440p does well with 27" and 32")
Ultrawide: No
Refresh rate: 144 Hz (or up)
Response time: 1ms
contrast ratio: min 3000:1
TN, IPS or VA panel: VA
Color Gamut: never considered that
Curvature: 1500R or less
VESA mount: Yes. Preferably 100mm and 120mm all in one
Input port: Display Port
HDR: I don't mind it
Internal speakers: Don't need them
How many USB ports: Don't use monitor USB ports, so, i don't care
Headphone out: Don't use that either
G-Sync: Neat thing if you have Nvidia GPU but increases monitor price considerably
Price: If it's good, i'm willing to pay premium price
Brand: MSI, Asus
Note: These above are my personal preferences and may not align or even match yours. Take them as a guideline to look for a monitor.
To pick a monitor, it's good when you know more about different monitor panel types. There are 3x kinds of monitor panels: TN, VA and IPS. Actually there are more (variations of the main three) but i focus on these main ones.
TN panel is oldest of the three and also cheapest. Where TN panel excels is it's performance, most notably response time (1ms).
Though, TN panel also has it's downsides. Prominent ones are: poor color accuracy (washed out colors), very narrow view angle and poor contrast ratio (max 1000:1).
Gaming wise, TN panel monitor is best suited for fast-paced games (FPS, racing etc), where you don't care as much about pretty colors as you do about smoothness of movements.
IPS panel has been around for some time and is also the most expensive of the three.
Where IPS panel excels is it's color accuracy, which is the best of the three. Also, it has widest viewing angles of the three.
But where IPS panel falls short is response time. IPS technology by design can't be any faster than 4ms (compared to the 1ms most TN panels are). Another area where IPS panel falls short is it's poor contrast ratio which is equal to a TN panel (max 1000:1), despite it's great color accuracy. This is most prominent when looking at black image and where black isn't black but instead gray or some form of blue. Refresh rates aren't IPS panel strong side either and many IPS panels are 60Hz, especially on higher resolutions. There are some 1440p 165Hz and 4K 120Hz IPS panel monitors out there but they are few and far apart, also costing a fortune.
Gaming wise, IPS panel monitor is best suited for slow-paced games (RPG, strategy etc), where you have time to see all those pretty colors and where smoothness of movements isn't that important.
VA panel is the newest of the three and price wise, it falls between TN and IPS. VA panel was created to take the best of both worlds (TN and IPS) and combine them.
Where VA panel excels is it's contrast ratio (min 3000:1), where you'd see the deepest and richest blacks. Also, it doesn't fall short on other aspects as well. VA panel color accuracy isn't as good as it is for IPS panel but it's close to the levels of IPS panel (considerably better than TN panel). It's viewing angle is also a notch smaller than that of an IPS panel but again, considerably better than that of a TN panel. Refresh rate wise, VA panel is more capable on different resolutions than IPS panel. Response time is another area where VA panel does good. While VA panel can't naturally be any faster than 4ms (just like IPS panel), it can achieve the magical 1ms response thanks to the software solution in it.
With VA panel monitors making waves lately, there aren't any major downsides of them. Availability used to be issue but not anymore.
Gaming wise, VA panel monitor is suited for all kinds of games. VA panel is like Jack of all trades but master of none (except when it comes to contrast ratio, there, VA panel is king).
With all that being said, i suggest looking towards either IPS panel (pretty colors but poor contrast ratio) or VA panel (jack of all trades, but superior contrast). Also, monitor refresh rate can be easily 144/165 Hz since even when you get ~90FPS, monitor does not make the smoothness worse. It's the other hardware in your PC that defines that (CPU, RAM, GPU and in some extent: SSD/HDD).
If you pop in other criteria (e.g taking mine as guideline), i could share some monitors for you within your budget.
