Monitor won't display 1080p on integrated graphics
bizzare21
76
Up to now, I've been using the DVI-D port on my monitor for my computer. But I'm getting an Xbox One and I want to play on my monitor using a DVI to HDMI cable, so I tested the integrated graphics on the motherboard and it wont display correctly. It defaults to 1024 x 768 and the highest it'll go is 1600 x 1200 at 64Hz. I've tried forcing a resolution by listing all the modes in Windows 10, but the option for 1080p still doesn't show. I've also tried 2 VGA cables. Does anyone know what to do?
Yeah that might work. If you uninstall your gpu drivers and connect your monitor to your motherboard's outputs you may force windows update to download the right drivers. :)
If it's not hard try it.. You don't have anything to loose.
I can't find the integrated graphics drivers
I see bios, audio, and lan drivers. Nothing for vga.
When you first open the folder there's AsusSetup.exe and Setup.exe. There's also 2 folders named Bin and Bin64 which both contain more Setup.exe files.
I'm just gonna try uninstalling my GPU drivers and see if that works tomorrow. I won't be needing them anyway. lol
I'm probably gonna buy a whole new monitor entirely. The one I'm using now is from 2009...
I don't think that your monitor age has anything to do whith this problem. I believe it's something simple. You will find it I am sure
