I recently built a new pc and i've had pretty much no problems except for the monitor was being kind of a pain. I didn't know i needed a display port or dvi cable at first so i ordered those and It still doesn't work. My dvi port won't show the monitor for some reason so i just have it plugged into a display port on my aorus gtx 1080 ti which i think should work perfectly fine but any time i try a resolution above 60hz it turns black and says no signal. also i thought the cable they sent with the monitor might be defective so i purchased another one and both had the same response.
I've got an acer g246hl
Other parts are
aorus Gtx 1080ti xtreme
EVGA 1000 GQ, 80+ GOLD 1000W
aorus z370 gaming 5 mobo
if you want me to list anything else that might help tell me
Other parts are
