Monitor won't start when plugged into graphics card
lowcountrysmoke
131
How come my monitor will not start up when I plug it into my graphics card? I have been using onboard graphics and everything works fine. I recently bought a graphics card and when i plug the monitor cable into it the light on my monitor remains yellow instead of green. If i take out the cable and plug it into the mobo i get a display so somethings screwy. When the graphics card is plugged in all the fans spin and the led's light up ..but no monitor display. Right now i have my gpu in the pci slot but have my cable plugged into the mobo. I am currently using an old monitor that uses vga (until i get my new one, it is a gateway2000 vivitron..yeh lol) so i have to use an adapter that msi provided when i plug it into my gpu. Maybe something is wrong with the adapter? The adapter looks like it has missing pins but i think that is normal with vga- dvi a, the a stands for analog. Could this be it? Since my computer has been running fine for a month now playing games and such, i doubt my psu is bad (also the gpu is getting power like i mentioned earlier). I have tried to start up with graphics turned to pci express- still nothing, I have tried with and without drivers- samething.. I am stuck and not sure what the problem is.. Please help
Specs: msi 7870 hawk, i5 3570k, 600w cx corsair, asrock z77 pro4 and the rest is irrelevant.
hmm, I'm not sure. That is very odd. I was thinking you could have both connected have your onboard set to default. Then go in and install the driver to your video card and then disable your onboard then restart and in the bios set it to pci express priority and then save and exit and see what happens but i'm not sure at this point.
Things you've tried.
1. Going through Bios and changing did nothing: check
2. Disabled onboard video through device manager: check
3. Tried other full length pci express slots?: maybe?
I found a older article it looks pretty considerable to me I would get in contact with ASROCK. No reason you should have a fully capable card and motherboard only to be held back by a weird slot.
http://www.techpowerup.com/reviews/AMD/HD_5870_PCI-Express_Scaling/
Not much depending on the application and gpu used.
There are more lanes incorporated into the 16x & 8x slots feeding off the cpu controller whilst the 4x is using the chipset controller.
Benchmarks are hard to find quickly but did find a youtube video testing a 6990 in each 16/8/4 slot.
http://www.youtube.com/watch?v=rSfifE2Domo
The scores aren't much different, but he did mention he'll have a more intense benchmark next time.
So guess for now you'll be fine, but if upgrading to a more powerful gpu in future could be restricted even further as more powerful gpus start to take full advantage of 16x.
Right but there is no reason why he shouldn't be able to take advantage of his motherboard's full purpose of him being able to run his card at full bandwidth I would talk to ASROCK and see what they say maybe there is a way for them to instruct you in changing your pci-express 3.0 to a 2.0 speed slot. Also maybe there is a bios update that would solve the solution
