Monitor wont work
jhutcheson
61
I've just finished my long awaited first ever build. I got it to turn on with everything working first try so it seemed. I plugged it in to my monitor now and the screen goes from a picture of the dell logo and 4 colors to a blank screen. I've researched it quite a bit already and I cant figure out the problem. I have no idea whats going. I've been messing with the hard drive thinking the jumper was the problem but no luck so far. Any help is appreciated.
Here is my full build: http://pcpartpicker.com/user/Tempers/saved/9CX323 That's actually not the monitor im using for this though. Im using an old Dell monitor with a model number of 1907FPc
Thanks all :)
After just a few more minutes of searching, I came across pictures of all the different kinds of dvi cables. It seems my gpu uses dvi-d dual link and the cord im trying to use a dvi-d single link. Seems like a simple fix and will have to pick one up tomorrow. Hope this helps others if youre as silly as me 😛
