So yesterday i got home booted up my PC and nothing monitors were blank and not turning on and the pc would spin up the drives and fans then reboot constantly until i hit the power button.
I ended up opening it up and noticed it was a little dusty so i cleaned it all up.
It booted up fine, i played some games for a few hours and then all of sudden the screens went black and the pc started the same reboot issue.
So i pulled out the GPU and still nothing, stuck in boot cycle.
I pulled everything except cpu, ram and monitor. It booted to BIOS.
So i plugged in the SSD, booted.
Plugged in HDD, booted
Plugged in front USB, booted
Put the GPU back in, booted.
Not sure what the issue is.
I am not sure what the temperatures were when it crashed. I'm also not sure if either the machine cooled down enough to start or if a component is having issues.
I ran a memory test, everything was ok.
I ran S.M.A.R.T test on my SSD, everything is ok. (speedfan)
The temperatures using HW monitor or core temp seem fine at idle. So do the supply power to the components.
Any guidance would be appreciated.
