[SOLVED] Most quiet low profile cooler for 12600K ?
Regev
290
18
10,685
I'm building an open-air 12600K rig (non-OCed).
On my 9900K, I have the NH15 on Silent mode, and it is indeed silent. I can't hear that computer at all.
I'd use another NH15, but on this build I don't have the space for that gigantic cooler. Which low profile cooler will give me similar quietness, while sufficiently cooling a non-OCed 12600K?
If no air cooler exists (I understand with smaller heatsink, you need bigger/noisier fans), is there any silent (maybe even passive?) AIO cooler I could use?
Thanks
What is your height restriction? (in mm)
"Low profile" isn't specific enough.
Scythe Big Shuriken 3.0
https://www.scytheus.com/bigshuriken3
Noctua NH-L12S
https://noctua.at/en/nh-l12s
(Sorry for the super tall pics) Both coolers are included here. Keep in mind these are open test bench results (InWinn D Frame)
What is the height available for a cooler?
How low profile do you need?
What is the make/model of this open air case?
A i5-12600K may well run with any cooler you use.
But to get the max turbo boost, you need a cooler that can keep temperatures to under 70c.
That will not happen with any low profile downdraft cooler.
A cooler needs some radiator size to do it's job.
Noctua maintains a list of suitability of coolers for the 12600k:
https://ncc.noctua.at/cpus/model/Intel-Core-i5-12600K-1581
Also, if a cooler uses larger 120/140mm fans, it will be quieter.
I gave up on finding a small enough VESA mountable case, so I'm just drilling the motherboard and SFX PSU to the wall, and cover them with a beautiful piece of glass drilled with 4 spacers to the wall. Will look kinda like the Thermaltake Core P1, just much smaller. I get to decide what length the spacers will be, but for sure they won't fit a big cooler, cause it will look weird :) I was worried of using AIO (because of potential leakage, it's an improtant production machine), but I thought maybe if I could position the radiator correctly I can use gravity so that water won't ever touch the electronics, even if leaked. What's the most silent (both fans and pump) AIO perhaps?
Nice thanks! The Big Shuriken 3 does looks interesting. Will it be more silent than an AIO system?
* as for height restriction - I get to choose which spacers to use, I just don't want too much space between the glass and the wall, so would rather use a low profile cooler. Can that Shuriken keep a non-OCed 12600K under healthy temps (remember, the case is open) and remain dead silent when doing basic stuff like browsing?
On my Noctua D15, I set it as Silent on the bios, and I don't hear it at all, cause I never go crazy with that computer. I'd like to achieve a similar quietness with this build, tho I'm aware of the limitations of a smaller cooler.
I might suggest the noctua NH-C14s.
https://noctua.at/en/nh-c14s
It looks to be suitable:
The big advantage is that it uses a 140mm fan or two which will be quieter than 120 or 92mm fans.
There are a couple of options to adjust the height, depending on one fan or two, and mounted over or under the cooling fins. It can go from a minimum of 115mm to 142mm.
I have used the big shuriken rev b before in a height restricted case and an overclocked 6600K.
It was the best available at the time.
I like the scythe products, they have performed well.
But, under heavy load the fan which is thin at 15mm, became noisy and was unable to sustain the overclock that I wanted. I think you need stronger for a 12600K.
I like the open concept mounted on the wall.
You should get a good natural airflow without the need for any fans other than the cpu cooler.
https://noctua.at/en/nh-l12s/specification
Will the Scythe / L12s be enough tho, if I don't overclock at all?
At stock, the 12600K pulls about 120W.
In general, I would say yes, either cooler can handle a 12600K.
Downdraft coolers are more sensitive to good case airflow than tower coolers. In your situation of a custom case, care should be taken to allow the fan to breathe cool/fresh air and have some airflow across the CPU socket to move the waste heat away before the fan sucks [the "splash"] back in. Since you're looking to minimize height, make sure you leave some room for the fan to get air (don't press it up against a sheet of glass) and/or fab a vent above the CPU fan. If no vents, you'll want to leave a space at least the thickness of the fan above it.
Enough... yes it should run minimally.
Quiet...not particularly.
You really can't not overclock. Normal turbo boost will come into play.
For advertised turbo performance, the cpu needs to be no hotter than 70c.
Yes, you could undervolt and cripple the processor a bit.
The 12600K is such a good processor that you might not notice.
But, if you were willing to do that, why not buy a I3-12100 or similar in the first place?
Noctua does show that the L12s is suitable, but with a NSPR rating of only 88 I think I would go stronger.
The NH-C14s at 119,
Note... I included the wrong link in the post above which has been fixed.
More on NSPR ratings:
https://noctua.at/en/noctua-standardised-performance-rating
As a plus, you plan for an open mount looks good to me.
I assume the bottom and the top part will be open.
Normal convection should allow generated heat to flow up and out of the opening.
A general tower cooler is @ 160mm tall. The TF is 130mm tall with fans.(109 with under fan only) That 30mm difference is huge for many cases. It also is just behind the D15 in ability and capacity at 220w. For a 12600k there's even less difference as you'll not come close to maxing out its capacity, even with OC. By comparison, the Noctua L12i is @ 130w putting it on par with an AMD Wraith spire/stealth stock cooler, which in itself is miles better than Intel stock cooling. The C14s is 140mm with outside fan (115 with under fan)
With some cases maxing out at 150/152mm clearance, a 200w+ cooler is hard to fit, most times you get stuck with a 92mm tower like the Cryorig m9i and are lucky to see 140w capacity.
