motherboard advice, MSI B450M PRO-VDH vs b350 tomahawk
Oct 31, 2018
4
Hi guys,
building my very first pc, here
and just wondering which motherboard the msi b450 pro vdh or the msi b350 tomahawk will be better?
Thanks and cheers.
The link to the components is in the very first post.
I don't know much about mobos only wague basic knowledge, hence I ask.
as to its use, No major video games but heavy usage around 18 20 hours a day, would need it to work for a while that is longest without me having to change the processor or things, hence the choice of 2600x.
country india.
no components brought yet.
call the budget around 70k INR that keeps on changing to the doller plus the stuff is twice as expensive around here as compared to the USA.
the pcpart picker link that I have posted has the b450 mobo because its a newer chipset and is cheaper, but what I am asking is is there any pros or cons to geting one mobo over the other? quality? something one is better at that the other isn't?
the b350 is updated to support the second gen amd processors by the way.
P.S. I'll be getting the gtx 1050-TI 4gb instead of the 2gb that the pc part picker link shows.
Thank you again!
Thank you for the reply.
