Question Motherboard Advice Requested for i9-12900k Build
qattack
Commendable
Nov 17, 2019
7
I will be building a PC with an I9-12900k CPU in a couple weeks, but I don't know anything about motherboards.
Here is a tentative parts list: https://pcpartpicker.com/user/qattack/saved/#view=jcwXRB
However, I currently plan on replacing the motherboard (I picked randomly) with a different one. The motherboard below was not contained in the PC Parts Picker list.
The following motherboard was top-ranked in two different lists: https://www.newegg.com/p/N82E168131... - intel-_-msi-_-9SIB2N5HC28582&source=region
Since I'm spending quite a bit already, I thought I may as well shell out an extra $300 for a better motherboard, but I'm not entirely certain exactly what extra benefits this motherboard really gives (and what is hype). I would appreciate any comments about it.
Thank You!
Looks like a Z390 board.
Totally incompatible with a 12900K. CPU will not fit in the socket.
If you want to spend a lot on a board for a 12900K, you need a Z690.
Whether a Z690 is "better" for your purposes is another question entirely.
Thank you, I suspected that it may not have been compatible since it wasn't displaying in PC Parts Picker. Turns out that I typed the wrong CPU in when doing the motherboard search.
The following motherboard was top-ranked in two different lists: https://www.newegg.com/p/N82E16813144209?item=9SIB2N5HC28582&nm_mc=knc-googleadwords&cm_mmc=knc-googleadwords-_-motherboards - intel--msi--9SIB2N5HC28582&source=region
Thank You!
As above the Z390 is for 8th gen, totally incompatible. You need Z690, if your going fancy then something like this would be what I'd look at:
https://www.newegg.com/p/N82E168131...on WiFi-_-13-144-484-_-Product&quicklink=true
