Motherboard and Graphics Card Compatible?
Javin
28
Hello! I was wondering if it was possible to be able to crossfire Geforce GTX 780's on a AMD motherboard? I heard that you are able to use 1 card for sure, but when you try and SLI/Crossfire Nvidia cards and AMD motherboard setups that's where you would run into issues. So is it true? Am I going to run into issues? Thanks
(Mother Board- http://www.newegg.com/Product/Product.aspx?Item=N82E16813130755)
Multi-AMD card setups = Crossfire
Multi-NVidia card setips = SLI
That motherboard only states that it supports Crossfire. You would not be able to run multiple NVidia cards in an SLI configuration with that motherboard.
-Wolf sends
-Wolf sends
