[SOLVED] Motherboard and Render with i3 6100
May 21, 2020
I have a processor i3 6100, i will change next year 9.gen i5 until that time i need a desktop and get render...
Therefore, We say I need new motherboard. If i get H310 motherboard Does i3 processor work? I looked msi h310m-pro vh cpu support list, there is i3 8100. But it means doesnt support? But i know 1151 lga motherboard works all 1151 processors previously...
Second question, You think, Can i get render Adobe Effects ann 3dmax with i3 6100 and 1050 ti?
Thanks
1st question: You need motherboard with chipset 1xx or 2xx
If you want cheap buy H110 Mobo
I would go at least with B250, they are not that expensive compared to the H110 and there is a big difference, also are you planing to use M.2 Nvme ?
Because if you do you should go with B250 that supports it!
ASUS PRIME B250M-A
or
ASUS PRIME B250-PLUS
they seem decent budged boards...
2nd question, i don't see why not. I think you should be fine, how much ram do you have?
ASUS PRIME B250M-A
or
If i get B250-PLUS, I cant use i5 9gen when i get, is it true?
Is there work both i3 6100 and i5 9400f??
Ram DDR4 16GB , will it be compatible 2400mhz with b250 motherboard, i guess i should 2133..
