Hello, here's my current build. I'm going to explain why I think the motherboard is dying, but you can skip the next paragraph if you don't care.
I recently started having issues with starting it up. It'll start, run for a few seconds, then restart without giving a beep code. If I shut it down and unplug it a few times, it'll eventually boot successfully. I RMA'd the power supply and that didn't solve it, so I've tried all combinations of the RAM and have tried booting without my graphics card--no dice. The only components left are my SSD, HDD, CPU, and motherboard. I doubt it's the HDD/SSD and I don't have a replacement CPU or motherboard to check, so I'm planning on just replacing the motherboard and seeing if it fixes it.
The problem is, the well-rated replacements on pcpartpicker are all discontinued. There's a few left that have a couple good ratings, but I'm hoping someone here can help me pick a good replacement. Any suggestions?
While I'm at it, I'm planning on adding a larger SSD as a new boot drive as well, so any suggestions for that too would be appreciated.
