Question Motherboard EZ DEBUG LED DRAM lit, no response from monitor
Jul 19, 2020
5
I was playing on my computer today and once finishing trying to install an rgb strip, my computer decides to break down. I couldn't start up my computer... All of my RAM sticks were fine, CPU was untouched under the CPU cooler. I reseated the CPU, GPU, Vertical bracket for my GPU, the RAM sticks as well and still no luck. I even only kept one RAM stick but that led into another problem. Once i left the one RAM Stick in, It passed the POST, but initiated an automatic repair, which now kept me in a loop. FIrst the CPU led came on, the the DRAM flashed for a quick second, then VGA lit for a second, then boot for a good 5 seconds and nothing else happened. It brought me to the automatic repair, then kept repeating the same process over and over. So when I put 3 Ram sticks, it does the same as putting one ram stick in, however if i put all 4, it stops the loop, but now puts me back at square one. Me not having a response from monitors, but all my RGB in the computer works.
Specs:
Motherboard: MSI B550 Tomahawk
CPU: AMD Ryzen 5 3600
RAM: Team T-Force Delta RGB 32GB 3200Mhz(4 x 8GB)
GPU: MSI NVIDIA RTX 2060
Case: Lian Li Lancool II (White RGB)
