Hello,
Recently build a pc with NZXT H9 Flow case and Gigabyte Aorus Elite AX V2 motherboard but I am confused on the cable that connects to the F_PANEL header.
Cable from the case labeled f_panel also connects to a chassis intrusion header CI -/+ pin, but only the negative pin.
Do I risk shorting my board? Am I missing a cable?
Can't find a similar problem anywhere.
https://www.manualslib.com/manual/2880842/Gigabyte-B650-Aorus-Elite-Ax.html
www.manualslib.com
NZXT H9 FLOW Manual (Page 10 of 38) | ManualsLib
