T technohyper755 Prominent Dec 16, 2017 25 0 530 May 31, 2018 #1 I wanted to buy a Asus Strix Z370-f motherboard which has 1 x M.2_FAN connector 1 x CPU Fan connector(s) 1 x CPU OPT Fan connector(s) 2 x Chassis Fan connector(s) 1 x AIO PUMP Header. can i use this connector as a case fan connector? http://
madmatt30 Titan Ambassador Jan 1, 2013 24,571 647 91,240 May 31, 2018 #2 You can , whether it'll allow co,trol,of the fans rpm will depend on whther it's 3 or 4 pin & if it's 3 pin whether it allows voltage control. Worst case , it'll run full speed. Upvote 0 Downvote
T technohyper755 Prominent Dec 16, 2017 25 0 530 May 31, 2018 #3 madmatt30 : You can , whether it'll allow co,trol,of the fans rpm will depend on whther it's 3 or 4 pin & if it's 3 pin whether it allows voltage control. Worst case , it'll run full speed. i wanna use 4pin pwm fans in this headers because i want to use asus fan control software via this connector with pwm fans Upvote 0 Downvote
