I am upgrading my PC after a long wait and going for the Ryzen 7800x3d about 524 US dollars in my country, I did some research but that made me very confused about the motherboards.
ASUS motherboards are bad for 7000 series
Earlier I was interested in a Gigabyte B650M Aorus Pro AX (Wi-Fi) Motherboard -
mdcomputers.in
It is costing me around 280 US dollars in my country.
Gigabyte boards have the best and precise timings for the 7000 series, but I am skeptical to go for it because gigabyte has coil whine issue.
Should I go for it or try some other boards, but the only problem is they are not as good as gigabyte, hardware unboxed did some testing and even found out lower FPS in the other boards -
View: https://www.youtube.com/watch?v=DTFUa60ozKY
As for the ram it is very hard to find a 6000 mhz CL 30-38-38-96 but I have found one CL 30-40-40-96, how much slower the latter is? Should I go for it?
Gigabyte B650M Aorus Pro AX (Wi-Fi) Motherboard (AMD Socket AM5/Ryzen 7000 Series CPU/Max 128GB DDR5 6666MHz)
Gigabyte B650M Aorus Pro AX WiFi | M-ATX 128GB DDR5 Motherboard | Supports AMD Ryzen 7000 Series Processors | Direct 12+2+1 Phases Digital VRM Solution | PCIe 5.0 M.2 SSD Performance | 2.5GbE LAN & Wi-Fi 6E...
