[SOLVED] Motherboard Front Panel Connectors
Apr 15, 2020
I have an ASUS ROG STRIX B450-F motherboard and I’m having trouble with where the front panel connectors go. I have what appears to be an adapter with four connectors labeled “power sw” “-p led” “+p led” and “h.d.d led”. I’m pretty sure they go in the bottom right corner but I’m not exactly sure.
Yes you're correct about the position where the front panel can be found... it's in the botom right corner of the board.
I'll leave a diagram with the significance of every pin:
You should be able to plug the connectors the right way if you follow this pinout diagram.
