So this is a problem I have been struggling with for well over a year, and continuously re-surfaces whenever I upgrade my setup.
The Problem:
Since the day I installed my motherboard, MSI z170A Gaming Pro Carbon, I have not been able to use 6 out of the 7 USB ports. The one port that works is the single USB 3.1 Gen 2 Type A, The remaining 3.0 and 2.0 ports receive power, but are unresponsive. I have coped by using the one working port and an external USB hub for all my devices. When I plug a device into any of the other 6 ports, I get an unrecognized device error and "Unkown USB device (invalid device descriptor)" in device manager. See screenshot below
https://imageshack.com/a/img922/7880/9Nusu3.png
IMPORTANT: I would also like to note that the HDMI port on the motherboard is also not working, although I didn't notice until now. The oddest part of the situation is that all the ports work fine when in BIOS, but malfunction shortly before windows loads. This is what leads me to believe it is a software problem, and therefore can be fixed.
Thought this was weird
While looking for a solution in my BIOS, I noticed a setting called "Windows 8.1/10 WHQL Support" was disabled, while the setting underneath it "Windows 7 installation" was enabled. Knowing that I have windows 10, I messed with these settings and found that enabling/ disabling both of these settings, respectfully, led to a boot right back into BIOS.
What I have Tried
So far I have gone through all the common solutions:
-uninstalling/reinstalling USB Root Hubs and other controllers
-disabling power restrictions in device manager and windows settings
-updating bios
-updating motherboard drivers
Please help! There are so many things that could be causing the problem, so any input is welcome and greatly appreciated. Thanks in advance!
The Problem:
What I have Tried
-updating bios
