Motherboard:ASUS Prime X370-Pro AMD Ryzen AM4 DDR4 DP HDMI M.2 USB 3.1 ATX X370 Motherboard with AURA Sync RGB Lighting
I lost my original jumper cap so I bought a 100 pack on Amazon (Link: https://www.amazon.com/2-54mm-Standard-Computer-Jumper-100pack/dp/B00N552DWK/ref=sr_1_3?ie=UTF8&qid=1534290490&sr=8-3&keywords=jumper+cap ) It does fit into my jumper pin but it didn't fully cover the pin, will it still work? Also, someone told me to short it with a screwdriver, but I don't know how to do it. Please give me the instruction on how to do it, along with some pics will be great. Thanks in advance.
Here's my pin:
Here's the pin with jumper cap on. I don't know if you can see it or not, but the cap doesn't fully cover the pin:
Here's my pin:
