Motherboard LED lights up but PC won't start
bojjan
4
Hi!
So I decided to put together my old pc again to use as my backup. But once I pushed the power button nothing happened, nothing at all. So my first thought was that I had plugged the power switch incorrectly into the motherboard, so I checked and that wasn't it. Then I checked if any of the motherboards LED's got any power, and they do. I'm completely stumped, please help.
Specs :
CPU: i5 6600k 3,5ghz
PSU: Corsair CX500
Motherboard: Asus P8Z77-v lx
RAM: Corsair Dominator 16gb
OS: Win10
Yes, both are connected correctly, there is no way for them to come out without manually pressing down on the hooks.
I know, it's my old pc so the parts are quite outdated and weak.
I'm using a GTX 660, I forgot to put that into my specs, sorry. I don't know what a discrete GPU is, so I don't know if I have one or not.
The driver's for the gpu is already installed since I was using that exact setup before I retired the pc, so everything is the same in the computer except for new cooling paste on the CPU.
