I just installed a new zalman cooler on my mother baord and degreased and applied some mx-2, and now My computer won't even attempt to turn on, even though the green light on the motherboard is as bright as day. I tried using a different cpu, different ram, I'm alost positive its not the case, it was working earlier today, I suspect that the power supply may have gone bad. The specs are as follows:
Motherboard: Asus p5kpl-cm
Memory: 4gb (2*2gb) OCZ Reaper 1066 mhz ddr2
CPU: Intel e8500
Graphics: 8800gts
Power Supply:LOGISYS Computer PS575XBK 575W ATX12V SLI Ready Power Supply
Can someone please help me out, The jumper settings are fine according to the manual, everything was in working order earlier today before I had to take out the motherboard to apply the back plate. I am highly confused, someone please help.
I am going to try bread boarding in the morning, if this still does not work, I will be at a loss once more, and will probably end up buying a new PSU unless otherwise directed logically
CPU: Intel e8500
Graphics: 8800gts
