Long story short: <Mod Edit> went down, someone spilled water into my tower, most water hit the floor but there was a little bit inside, i found small puddle on top of the GPU (and maybe inside...) and on top of the SSD. Could have been other places too but i didn't see any.
The PC was in sleep mode and I hurried to flip off the power supply and unplug as fast as i could, but maybe i wasn't fast enough.
So after unplugging i opened the tower and had some table fans i put on to blow into it for about 8 hours and I left it in the room which is very dry for the next 24 hours. Before coming back to it to check.
Nothing was wet so i tried to plug in power again to see, and all the lights inside go on but it won't boot up.
The red light on my motherboard that says CPU is lighted and i have tried to troubleshoot to find out if any other component were causing it to not boot but no result.
I have tried to unplug every other part but it seems either its the Motherboard or PSU maybe that causes it to not boot up.
Does anyone have any suggestions? I don't mind changing any of my parts but I need to find out which one is broken
Motherboard is Asus ROG Strix Z270F Gaming.
Here is a picture of inside when i flip the power switch on: View: https://imgur.com/touMQ4s
