[SOLVED] Motherboard mounting screws stuck in the cpu cooler, how do I fix it?
Sakido
5
So I was in the process of finishing up my PC build and when I booted it up, there was a loud buzzing sound coming from the cpu cooler so I tried to remove it to see what the issue was with it. Apparently I screwed it in too hard because when I went to remove it from the motherboard, all of the screws to mount the cooler to the motherboard came off with the cooler itself and now I can't put it back on. Everything else seems to work fine and there was no other damage to the motherboard, but I have no idea if I completely broke the motherboard or not. Any help would be appreciated.
This is what it looks like now: View: https://imgur.com/a/CL3qtA9
Specs:
Ryzen 5 1600 AF
Stock Ryzen Cooler
ASRock B450M-HDV R4.0 AM4 Motherboard
GSkill 16GB DDR4 Ram
WD 500GB SSD
EVGA 600W BQ PSU
