Motherboard Not Receiving Enough Power
Apr 29, 2018
7
Hi I just finished building my first gaming pc and I plugged everything in but when I hit the power button the cpu fan does a half spin and nothing else turns on. The HDD drive doesn't even spin, neither do any of the 2 fans I have installed. I rearranged everything and tried again. I realized that I hadn't put the standoffs on so I took out the motherboard and put them in. When I put it all together again the same thing happened. I'm also having issues deciding which 2-pins and 4-pins connect to the 3 4-pin molex I have because I always end up leaving one unplugged. Please help I really hope I don't have to buy a new PSU because I don't have a lot of money. Thank you so much for your help in advance!
My Parts:
Gigabyte Amd AM3+ Motherboard 78LMT-USB3 R2
AMD FX 8350 Black Edition 4GHz Eight Core (FD8350FRHKBOX) Processor
Kingston HyperX 8 GB DIMM 1600 MHz DDR3 Memory
Seagate 1TB SATA 3.5 Hard Drive
SanDisk SSD 2.5" 240GB Internal Solid State Drive
EVGA 650 N1, 650W Power Supply
AeroCool Mid Tower Cases Xpredator-X1 Black Edition Black
Old Intel optical drive
Nvidia GTX 770
I am planning on booting up from Windows 7 then upgrading to Windows 10.
If you just bought these pats, return them you have made some serious terrible choices with your parts selecion
then make a post asking for help building the best gaming rig for your money
seriously, return the parts if possible
Like the above poster mentionned, you seriously should try to return those parts. They are quite old and you could probably get something better for around the same amount of money.
Also, how did you even manage to fix the motherboard to the case without standoffs in the first place?
I highly suggest that you follow tutorials on how to build a PC before damaging anything. Youtube also has great tutorials that can teach you how to build a PC from scratch.
Thanks for the help
